BROKEN PANEL
(Topic created: 12-08-2025 01:12 PM)
thanassis
LED and OLED TVs
The day before yesterday the screen on my Samsung QE77S90C Smart 4K Ultra HD HDR OLED TV broke and I asked how much it would cost to replace it. While the TV currently costs around โ‚ฌ1600, I was told that the replacement would cost โ‚ฌ2550, which is unacceptable ....... what shall i do bay another samsung tv?  why not change brand to find a better solution than change tv, if i brake the panel???
thanassis
LED and OLED TVs
as i said the replacement of the panel is the only solution and the cost i was given is โ‚ฌ2550
meself
Honored Contributor
LED and OLED TVs
Did you try getting it repaired
thanassis
LED and OLED TVs
thanassis
LED and OLED TVs
