Can't find Philips Hue Sync on 2025 S95F OLED TV
(Topic created: 10-25-2025 03:48 AM)
pintsik998
LED and OLED TVs
Why can't I find Philips Hue Sync on my recently bought 2025 S95F OLED TV. It's the highest end model yet it's not available? If so, why!?
Pianodude58
Honored Contributor
LED and OLED TVs
You can't find Philips Hue Sync on your 2025 S95F because the app isn't available for Samsung TVs; it was discontinued and replaced with a new app for LG TVs in 2025. Samsung is the only major TV manufacturer that used to support this feature, and they stopped updating it. To sync lights with a new TV, you will need to purchase the Philips Hue Play HDMI Sync Box and connect it to your TV and media devices.
Pianodude58
Honored Contributor
LED and OLED TVs
Jaydenbyront
LED and OLED TVs
Thank you so much omg. I’ve been looking EVERYWHERE for guides and nobody ever addressed that. Philips literally says the new models are compatible, and SAMSUNG still has the guide online. So thank you for explaining why it wouldn’t work 🙂
Alex44
LED and OLED TVs
Well i have the App and everything works. TV is 3 weeks old .
