- Mute
โ01-22-2026
05:54 AM
(Last edited
โ01-22-2026
06:51 AM
by
SamsungStephani
My remote will only go to Samsung LiveTV. I can manually type the live TV number and it will come up, but not by scrolling the up and down channels from the remote control. I have rebooted the TV, changed batteries on remote, reset the remote... nothing works. My input/source says Samsung TV and I don't know how to change it.
Solved! Go to Solution.
- Mute
โ01-22-2026 05:31 PM in
LED and OLED TVsSo, I am replying with the answer that I received in less than 2 minutes from the Customer Support #...
Go to guide. Navigate to far left of guide and up to where it says "Filter By:" It should be on All.
Adham is my hero!
- Mute
โ01-22-2026 07:08 AM in
LED and OLED TVsHello Mhaller,
we would love to assist with the TV to ensure you're receiving the best experience possible. Are you using external device such as an antenna? We recommend for local channels, to connect an antenna and run an "Auto Program" scan in Settings > Broadcasting, choosing "Air/Antenna". For streaming assistance, you will press the Home button and launch Samsung TV Plus for free options or download other live TV apps from the App Store.
- Mute
โ01-22-2026 10:38 AM in
LED and OLED TVsYes, I am on an antenna... I already did that. It shows I should have 106 live tv stations. And if I put in the channel number, it will change to the live TV channel. But if I use the up/down button or go to the guide, it only shows Samsung channels and will only go to SamsungTV
- Mute
โ01-22-2026 10:39 AM in
LED and OLED TVsThanks... I already tried that. Rebooted TV and Router twice.
- Mute
โ01-22-2026 12:19 PM in
LED and OLED TVsThank you so much for that verification. When rebooting the TV, are you performing a soft or hard reboot? We have this article here to assist with the hard reboot/ reset https://www.samsung.com/us/support/answer/ANS10005248/. If this is unsuccessful we recommend for you to contact our support line at 1-800-Samsung for our remote management department.
- Mute
Adham is my hero!
