Cannot Label HDMI (OLED QN77S90DDF) input Firestick.
(Topic created: Tuesday)
BK_83
LED and OLED TVs
Two weeks ago in installed my 77" Samsung OLED QN77S90DDF, I plugged my Firestick into HDMI_4, and the setup automatically labeled the HDMI port as "Firestick."
After moving it to HDMI_2, the Firestick works fine, but I can't get the HDMI port to display the "Firestick" label.
I've tried:
  • - Navigating through the "Connection Guide" menu
  • - Exploring the "External Device" menu
  • - Performing a "Factory Reset"
None of these actions have resolved the issue.
HELP!
realaud
Honored Contributor
LED and OLED TVs
Is there any reason you cannot keep it plugged into the original HDMI port? Have you tried plugging another device into the "firestick" port to see if the name changed (or even the other device even works in it). Have you read through the manual to see if there's a setting to manually name each port?
BK_83
LED and OLED TVs
With HDMI 2 open it would open my home theater in HDMI 3 eARC.
The firestick in HDMI 2 and TV both function.  I just want to label HDMI 2 FIRESTICK when it was in HDMI 4.
I have read all references to HDMI in the manual and there is no manual ability to name, unlike the model  UN55H6300AFX I replaced.
Robin621k
Honored Contributor
LED and OLED TVs
HDMI 2 is usually reserved for the eARC port. Maybe that is why it isn't recognizing the Fire Stick!
BK_83
LED and OLED TVs
No HDMI 3 is the eARC and is successfully used for my home theater.
Robin621k
Honored Contributor
LED and OLED TVs
Yes, I just looked at the back oline.
It's weird that it doesn't do it automatically !
