DU7200, bluetooth headphones, Multi-Audio output
(Topic created: 09-03-2025 03:11 PM)
Traveler1946
LED and OLED TVs
Most times when I connect my Bluetooth headphones it disables the existing audio connection to the TV speaker system and I have to go into Settings and re-select Multi-Audio to get the speakers back for other people in the room. This wouldn't be a problem if there was a simple toggle but I counted and it takes 12 remote button presses to bring up menu/settings/all/general/accessibility/multi/on and then back out.
Maybe there's a specific sequence of powering up the TV and headphones that would work better?
