Disable vision Ai pop-up
(Topic created: 10-07-2025 10:52 AM)
JD16
LED and OLED TVs
Now a couple of dayโ€™s I get a pop-up to start Ai on my Samsung oled s95f. There is no option to disable this feature. I can cancel it but every day after turning on this pop-up keeps appearing and blocks whatever you are looking at for a couple of seconds.
I donโ€™t want this function. How to disable this is there an option or is this a bug. I donโ€™t want to be forced or use this.
Samsung_Moderator
LED and OLED TVs
Hello @JD16, welcome to the Samsung Community!
Vision AI is part of the Intelligent Mode suite, which automatically adjusts picture and sound settings. To regain full manual control, simply turn off Intelligent Mode:
Press Home on your remote.
Go to Settings > All Settings.
Navigate to General & Privacy > Intelligent Mode Settings.
Toggle Intelligent Mode to Off.
Let us know if this helps!
Make sure that you have the latest software version: https://www.samsung.com/us/support/answer/ANS10002051/
usertR7RAKAAK0
LED and OLED TVs
I have this same issue on my S90F and there is no "Intelligent Mode Settings" under Settings > All Settings. Please advise.
Dani2888
LED and OLED TVs
My tv does not have that setting option. I have a Q7F that is less than 4 months old.
MBWillo
LED and OLED TVs
The S95F 77โ€ does not have an option for Intelligent Mode Settings in the General & Privacy section.  I was unable to locate that menu option in any of the sub menus.
RetroNutcase
LED and OLED TVs
You're pointing us to settings that literally don't exist.
userzZT3vWfsFl
LED and OLED TVs
S95F does NOT have this 'Intelligent Mode' setting anywhere in the settings menu tree.
PLEASE for the Love of God, get rid of this unwanted 'feature' where these unhelpful AI Pop ups show up every day to interrupt what I'm watching. Or, fix the settings menu so that it can be disabled. Either way, I spent a LOT of money on this TV, I expect to get a firmware update to fix this, this is a bug and a major unwanted annoyance.
JD16
LED and OLED TVs
Yesterday your answer was very quick but the option, General & Privacy > Intelligent Mode Settings, isnโ€™t available like others also mentioned. So your proposed solution doesnโ€™t help at all.
Any other ideas? This Shouldnโ€™t be a problem to disable this and looks like Iโ€™am not the only one.
JD16
LED and OLED TVs
Yesterday you were very quick with the answer. But like also other have mentioned this option, General & Privacy > Intelligent Mode Settings doesnโ€™t exit. So your proposed  solution doesnโ€™t work.
Any other ideas? Shouldnโ€™t be hard to fix this, and I know that Iโ€™am not the only one with this major problem.
Samsung_Moderator
LED and OLED TVs
Sorry about that, I didn't realize your model didn't have the option to go to the settings. To better assist with this concern; Can you provide the specific model number of the TV? I understand that dealing with Pop-ups can be tedious. Currently, we do not have a way to turn them off, but certain models can time them out. We can look further into this matter, once we have the model number. Thank you.
