External IR Receiver for Samsung OM46B (3.5mm IR IN)
(Topic created: 02-19-2026 12:15 PM)
Catthewho
LED and OLED TVs
Hi,
I have a Samsung OM46B (Model Code: LH46OMBEBGBXEN). The display does not have any physical buttons, but it does have a 3.5 mm “IR IN” port.
Since I currently can’t control the display or switch inputs (for example to HDMI), I’m planning to buy an external IR receiver/sensor.
My question is:
Which external IR receiver (3.5 mm) is compatible with the OM46B?
Will a universal 3.5 mm IR receiver work, or does it need to be a specific Samsung signage IR sensor?
I want to make sure I purchase the correct type (receiver/sensor — not IR emitter or HDMI IR extender).
Thanks in advance for your help.
1 Reply
Samsung_Moderator
LED and OLED TVs
Hi @Catthewho and welcome to the US community! The model code you've provided is pulling up an international business model. As we are only able to provide support for US models, you will need to use the following link to get the support you need: https://www.samsung.com/uk/business/support/
Have a wonderful day, and thank you for reaching out! 🙂
