- Mute
05-29-2025
06:45 PM
(Last edited
06-12-2025
05:03 PM
by
SamsungCaleb
) in
Max App is not installing on Samsung TV 75 inch. Did Samsung and HBO had a fallout or something?
Solved! Go to Solution.
- Mute
06-02-2025 06:38 AM in
LED and OLED TVsHi there, Thanks so much for asking about this. I can definitely understand wanting to get the Max app up and working on your TV. Do you receive any type of error messages when trying to download the app? It's possible it may still be a memory issue, even though you've deleted some apps. Are you able to check the available space on your TV as well as the required space for the Max app? Lastly, if you haven't already, I recommend updating and resetting your TV. I'm providing links below with steps on how to do each of these. Please let us know if this helps.
1. Update:
https://www.samsung.com/us/support/answer/ANS10002051/
2. Reset:
https://www.samsung.com/us/support/answer/ANS00077524/
- Mute
05-29-2025 06:56 PM in
LED and OLED TVs- Mark as New
- Mute
05-29-2025 10:00 PM in
- Mute
05-29-2025 07:09 PM in
LED and OLED TVs@JossXL47 Watched Max on my 75 in Samsung TV just a minute ago. Worked fine.
- Mute
05-29-2025 09:59 PM in
- Mute
05-29-2025 10:06 PM in
LED and OLED TVsYour best bet is to get a streaming device.
I own the Google TV 4k Pro from ONN a Walmart brand. It is really snappy has a great remote and the biggest plus, it has a built in speaker which gives hands free access.
- Mute
05-29-2025 10:24 PM in
- Mute
05-29-2025 10:32 PM (Last edited 05-29-2025 10:33 PM ) in
LED and OLED TVsApps get updated regularly because they are from the Playstore.
- Mute
05-30-2025 08:08 AM in
- Mute
05-30-2025 08:06 AM (Last edited 05-30-2025 08:06 AM ) in
LED and OLED TVs@JossXL47 The app isn't installing (i.e. error during install), or you can't locate it to install, or ...?
If you can't install it, have you checked to see if you have adequate free memory on your TV?
And it is just MAX app. They dropped the HBO years ago, but have decided that it will be added again in the near future. But so far, it is just the MAX app.
