IPTV not working
(Topic created: 07-15-2024 10:34 AM)
Members_mK1oini
LED and OLED TVs
I have a TU7000 65 inch tv. None of the IPTV apps are not connecting. Netflix is working. I can use the Mu3 file on my laptop and it works. So I know it is not the network. Is anyone else having this problem?
Samsung_Moderator
LED and OLED TVs
Since this is still occurring this is just a compatibility issue. I would recommend getting a set-top box to get the full features on the IPTV to work.
Samsung_Moderator
LED and OLED TVs
Hi there, Thanks so much for asking about this. Have you checked to make sure the TV software is up to date? You may also want to check if there are any app updates for the affected apps. If everything is updated, I recommend resetting the Smart Hub on the TV. You can find steps on how to do this here:
https://www.samsung.com/us/support/answer/ANS00077524/
Members_mK1oini
LED and OLED TVs
i have tried all of the things you mention. The problem still exist.
Samsung_Moderator
LED and OLED TVs
Members_mK1oini
LED and OLED TVs
i have the same problem. My tv firmware is up to date. I am able to see the iptv channels and stream on my laptop but none of my iptv apps are showing any content. Netflix works fine.
Samsung_Moderator
LED and OLED TVs
Hi! @Members_mK1oini!  Thank you for reaching out.  A few questions that I want to ask to get a better idea.  Are you mirroring the IPTV service from your computer to the television?  The apps don't always play nice with the television, so it's a high possibility that if you are attempting to use the app on the television itself, you won't be able to get it to function due to limitations on the television.  If you're trying to watch an app on the television, you'll be better suited to get an external set-top box and install it on there to get full functionality of your IPTV on the screen itself.
Don't hesitate to reach out if you need additional assistance or have any additional questions!
