- Mute
06-08-2025
10:59 AM
(Last edited
06-12-2025
05:02 PM
by
SamsungCaleb
) in
I recently purchased a 77" S95F OLED TV (Model #: QN77S95FAFXZA). When I purchased the TV I also got a Samsung soundbar (HW-S800D). The TV was in stock so I took it home and set it up, the soundbar had to be shipped. The TV worked well when set up by itself. However, once the soundbar arrived I set it up and plugged it into eARC (hdmi 3). It connected and was working with qsymphony. But after a while we noticed that the sound would stop working and the tv would start cutting back and forth from tv output to eARC. power cycling things or manually turning off and on eARC seemed to resolve the issue but after turning off the tv for a while and coming back the sound would be messed up again, switching back and forth from qsymphony to tv output. I tried several different settings and bought a new hdmi cable to try. None of it worked, so I returned the soundbar. I then bought a Sonos Arc Ultra soundbar.
I came home set up the soundbar using the same hdmi 3 (eARC) port and everything worked great, except, when turning off the tv and going away for a bit and coming back and turning the tv on again the same problem occurs, the sound doesn't work through the soundbar and the tv sound flips back and forth from tv output for a few seconds to hdmi-earc for about a minute and then back.
I reached out to support and they verified my firmware on the tv was at the latest version (1042), walked me through a factory reset of the tv, power cycled everything. The power cycling always fixes the issue in the moment but then it comes back.
They said the only other option was to schedule a service, but if the technician doesn't find anything they will charge me for the visit. I have no faith that the technician will find anything since support was unable to help. This is a brand new TV and Samsung's top of the line model. Is there anything else to be done but return it?
- Mute
06-23-2025 03:56 PM in
LED and OLED TVsHi there, I am in Portugal and have the same problem issue with my 65s95F and q990f soundbar.
- Mute
07-04-2025 11:56 AM in
LED and OLED TVsI'm posting an update for people that may have the same issue. I returned the Sonos Arc Ultra and got one more soundbar to try a Sennheiser Ambeo Plus. Of the three, this one seems to tolerate the short comings of the TV the best. After the TV has been off for a while, it will still on occasion have trouble activating the soundbar. However, when this happens audio just falls back to playing through the tv. Unlike the prior two soundbars (samsung and sonos) the audio doesn't continue to cut back and forth. It stays playing through the tv. And, unlike the other two that required unplugging things or toggling EARC on and off to get things working again, with the Sennheiser it will usually resolve if you just turn the TV off and on again. Though sometimes it requires you do that multiple times. One downside of the Ambeo is when playing content it will usually not play sound for a few seconds at the start of the video and then start. This isn't so much of an issue for movies, as sound generally starts before you get to the actual content of the movie, but for tv shows it can be a little annoying.
Another odd thing I've noticed is variance based on HDMI cables. I've tried probably between 7-10 different brand new hdmi cables through this varying from 18 inches long up to 6 ft long. What I've found is that the issue appears to get worse when using shorter cables. The one I'm having the most luck with now is a 6 ft cable that came with the sennheiser. Shorter cables even expensive ones seem to exhibit the problem more often. This seems to me to suggest maybe the TV can't tolerate things happening too quickly when communicating with the soundbar, but it's not totally clear. I hope this helps for those having the same issue.
- Mute
Tuesday in
LED and OLED TVsSo, i may have a solution. Deactive the option to directly load into the Smart hub, let the tv start the last app or whatever. That worked for me.
