Missing plus Channels
(Topic created: 06-09-2024 06:37 AM)
Khrachovy1
LED and OLED TVs
Why can’t I locate channels such as 2926 which other friends have access to on their Samsung TV
have model UN49KS8000
software version T-JZMAKUC-1260.1 BT-S
no missing software updates
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
The Samsung TV Plus channel list is tied to the Zip Code you enter when you set up your TV so it is possible that your Zip Code doesn't get that channel.  I would first unplug the TV for a few minutes to allow it to clear out it's memory and then see if the channel is there when it comes back up.   If you've had the channel in the past and it is now missing you could try to reset the Smart Hub from Settings and see if it repopulates the list after that.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
1 Reply
bill-e
LED and OLED TVs
Bill
