Neo QLED 4K QN1EF remote not working
(Topic created: 03-26-2026 10:43 AM)
Antboy1
Cosmic Ray
LED and OLED TVs
55 Neo QLED 4K QN1EF remote not working with HUB. To whom it may concern, you're telling me that my problem is solved.And it's not. Also, you're not allowing me to post anymore.
This is what I was talking about when I said it may be a software issue, correct me.If i'm wrong thank you
Samsung_Moderator
LED and OLED TVs
Thank you for providing the name of the TV. You can find the full model number and serial number here: Settings > Support > About TV or on the decal on the back of the TV.
Since you've reset the smart hub, and the Smart Hub still isn't working service will be needed.
Please feel free to reach out via Private message with this information:
Model Number
Serial Number
First and Last Name
Best Contact phone number
Address where the unit is located
Email address
If you'd prefer to go online call in here is the information for those options:
Online at https://www.samsung.com/us/support/service/
Contacting Customer Support at 1-800-Samsung (1-800-726-7864)
Samsung_Moderator
LED and OLED TVs
Hi, Antboy1, welcome you to the community! We understand your concern that the TV isn't working with the hub, and we're happy to help.
Is the remote working on the TV for other apps external devices and just not the Smart Hub, or is it not working at all?
Are you using the Samsung Remote or a different universal remote?
If you are using the remote that came with the TV, we would recommend reviewing this guide: http://www.samsung.com/us/support/troubleshoot/TSG10002214/
Please let us know if this helps or if you have further questions!
Jennaborst
LED and OLED TVs
I have tried repairing the solar remote-it was successful pairing, but still does not work on the smart hub/Home Screen.  I have unplugged the TV for 10 minutes-did not fix it.  I reset to factory settings-didn’t fix it. I held the power button to install updates- that didn’t fix it either.
Antboy1
Cosmic Ray
LED and OLED TVs
I'm having the same problem
Jennaborst
LED and OLED TVs
When I push the home button, and I am on the smarthub, the remote doesn’t work. I can push the Netflix button at the bottom, and once I am on Netflix, the remote works perfectly. Same with the prime video button at the bottom of the remote.
Antboy1
Cosmic Ray
LED and OLED TVs
Samsung_Moderator
LED and OLED TVs
Hi, Antboy1 and Jennaborst,
From your description of what's happening, I understand that the remote will turn on the TV and the app buttons will pull up the app, but the Smart Hub isn't working. Usually repairing the remote works, but you noted this isn't working.
With what you've provided, I am unsure if it is the remote that's the issue or if the Smart Hub is not working right. Here are a few things to check and a few questions to help narrow down where the problem lies.
  • Please check that there's nothing blocking the IR receiver area on the TV.
    Please check that the Home/Smart Hub button isn't stuck.
  • Have you tried a universal remote or using Smart Things on your smart phone to see if the smart hub responds with a different remote?
  • Can you get to the Settings with the Home/Smart Hub button?
  • Also, when you repaired the remote, did you try resetting the remote?
I recommend trying a full reset if the other remotes work and they are able to get the smart hub to respond or if the Solar Remote can get to settings and move around and select different settings.
Full reset of the remote:
Press and hold the Return and Ambient keys until the light blinks (the Ambient button is the button above the directional buttons on the right (it looks like tiled windows).
After the Full Reset, the remote would need to be paired again. (Press and hold the Return and Play/Pause buttons for at least 5 seconds until a message displays on the TV indicating that the remote is now connected).
If the Smart Hub itself is unresponsive, then resetting the Smart Hub should correct it.
Press the Home button, go to the Settings > Support > Device Care > Reset Smart Hub
You can also check out Self-Diagnosis for the TV:
Press the Home button, go to the Settings > All Settings > Device Care > Self-Diagnosis
Please let us know if this helps.
Antboy1
Cosmic Ray
LED and OLED TVs
I've tried everything you suggested.
Not working. I've been trying to fix my t.V for about four hours. During my research, I found out, it may be a software update problem. My current version, 1260
Samsung_Moderator
LED and OLED TVs
Thank you for your quick reply and letting me know you've tried what was mentioned.  Would you mind providing your model number so I can check the firmware?
Antboy1
Cosmic Ray
LED and OLED TVs
Try using the smart thing remote, same issue
