No Bluetooth support for DU7200
(Topic created: 06-09-2025 12:10 PM)
incantata
LED and OLED TVs
I bought a 32" Samsung DU7200 TV last November.  I tried to connect BT headphones only to find that there is NO bluetooth option.  Only options are 'TV speaker' and 'Optical'.  The e-manual says there should be bluetooth but I tried with 3 different BT headphones.  Nothing.
Any solution to this?
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! I would recommend trying the information in the following link:https://www.samsung.com/us/support/answer/ANS00085342/. Please let me know if this helps!
1 Reply
Samsung_Moderator
LED and OLED TVs
