No apps ?
(Topic created: yesterday)
RichardjA
LED and OLED TVs
There is no app store or apps section on my du8070.
Can't find help anywhere.
I've tried restarting searching etc.
All I can do is select an app or edit the order.
There is no app section or search, just the line of apps that came with tv
1 Reply
Samsung_Moderator
LED and OLED TVs
Hello, RichardjA. Welcome to the Samsung Community! We know how frustrating installing new apps on your TV can be. Here are some troubleshooting steps you can take to find the app store on your TV.
Access the Apps Menu:
Press the Home button on your remote control to access the Smart Hub, then navigate to the "Apps" section. (Usually on the far left side of screen)
Search for Apps:
Use the search icon (usually a magnifying glass) in the top right corner of the Apps screen to find the specific app you want to install.
Select and Install:
Once you find the app, select it and then choose the "Install" option.
Please let us know if this helps!
