OLED TV screen protector
(Topic created: 02-03-2024 06:23 AM)
SteveGuitarist
LED and OLED TVs
The TV was shipped with a plastic film on the screen to protect it. Which is great because I initially thought the scratch was on the screen itself.
Question: I left it on after installing the TV because I wasn't totally sure I wouldn't find the TV lacking a feature I like. (For example, not being able to decode DTS!!) Anyway, I left it on in case I needed to return it. Its been 3 weeks. Does keeping it on damage the TV?
Side note:  DTS decoding should be standard. Samsung wants you to buy a Samsung soundbar which low and behold DOES decode DTS. When this OLED goes, and I'm sure it will be soon, it will be my last Samsung TV. Can somebody say "Class Action Suit".
LongHiker
Galactic Samsung Care Ambassador
LED and OLED TVs
@SteveGuitarist The longer you keep that film on the screen the harder it will be to remove it.
TipsyTrex
Black Hole
LED and OLED TVs
Sony is the only major oem that still supports dts decoding.
I wish I could be in the room when the lawyer laughs you out of it.
SteveGuitarist
LED and OLED TVs
Well, in a "class action" suit nobody who sues goes to court. Just FYI. So, it seems all except Sony are trying to get over. Thanks for the information.
LongHiker
LED and OLED TVs
