ON / Off Timer On Samsung TVs?
(Topic created: 10-08-2025 08:10 AM)
big_baddawg
LED and OLED TVs
Does Samsung still make any TV's that have the Timer ON/OFF feature.  I don't want to use Alexa just want it in the TV.
realaud
Honored Contributor
LED and OLED TVs
If your TV is a smart TV  and connected to Smart Things (which I assume it is), you can create a schedule/routine to turn it on and off at specific times.  Open Smart Things, tap your device to bring up options, across the bottom will be a small menu, where you can find routines.  Then set your power on time and power off schedule.
Please mark any response that helped you as your solution.
Samsung_Moderator
LED and OLED TVs
Hey, thanks for the question. I believe most of our Samsung TVs have a Sleep Timer function. To access it, navigate to Settings > General & Privacy > System Manager > Time > Sleep Timer on your remote and choose your desired time. Is there a specific model TV you were looking at?
big_baddawg
LED and OLED TVs
Well I am not taking about a sleep timer. I am taking about an ON/OFF timer. Where you set the TV to come ON at a certain time and have a channel or input set then turn OFF at another time and repeat each day that you want One of my old Samsung plasma TV'S would do this. It had time and date as well
realaud
Honored Contributor
LED and OLED TVs
Samsung_Moderator
LED and OLED TVs
Thank you so much for sharing @realaud
