Please looking for help with knowing if my new 55" S90D OLED is working, needs repair or return
(Topic created: 06-27-2025 11:26 AM)
Figureguy
Halo
LED and OLED TVs
Good afternoon.  I could really use some help with this as I am not sure what to do.
I had a 55" Q80T I purchased in 2020.  When I hooked up my devices it recognized all 4 of them.  Spectrum Cable, Fire TV, Sound Bar and Nintendo Switch.  When I wanted to use my UHD Blu-Ray Player since I didn't have an open HDMI I would remove the Fire Stick and switch.  The TV would recognize the Blu-Ray and then when I was done and would change it again recognize the Fire TV.
With the 55' S90D I just purchased two weeks ago however I am having an issue.  I plugged in the 4 devices and the first time it only recognized the sound bar.  I had to manually configure the other 3.  I have spoken with Samsung numerous times and we have tried many steps to no avail.  We switched inputs, cables, etc.  Finally the TV recognized the Spectrum Cable but still not the Fire TV or Switch.  One time the TV recognized the Fire Stick as a Cox TV Cable receiver but then went away once I tried changing it again.  Nothing we did could get it to recognize the last two and I had to manually configure both.  Now if I want to use the Blu-Ray whatever I disconnect might not come back.
Samsung said on the phone that it should recognize the devices and sent a technician out.  They came today and looked at it.  He called Samsung Upper Tech Support while he was here and said that some of the newer TVs didn't say, for example, a PS5 if you had one connected because it might not have a contract with Samsung to have the rights for the icon.  All the devices seem to work but especially with the game system when recognized it would do a bit of the configuration itself.
He did some troubleshooting and nothing was showing as off.  This was an expensive unit (for me) and I just wanted to know if this is correct.  If it doesn't recognize the devices and I have to configure then I know what not to pull.  But if something is off, say like with the Cox TV detection, than I'd like to know.
It is still able to be returned or exchanged but before I go that far I would really appreciate if someone could take the time who might either have this TV or know of it if there is a problem.  Thank you so much for your help and have a good day.
