- Mute
08-30-2025 04:46 PM in
LED and OLED TVs- « Previous
- 1
- 2
- Next »
- Mute
09-16-2025 07:11 PM in
LED and OLED TVsYes I have 3 Samsung Frame TV's and the return button when in Samsung channels it does not go to the last channel if goes to a Samsung TV Home Screen. 7 Years owning multiple Samsung Frame TV's after the last firmware update the return button on all TV's does not go to the last channel. So frustrating.
- Mute
09-28-2025 03:38 PM (Last edited 09-28-2025 03:41 PM ) in
LED and OLED TVsIt appears to be a software update across Samsung TVs. It has affected my QN49Q6FNA TV as well (remote is RMCSPN1AP1). I suspect it is something within the smart hub perhaps, because when I FIRST turn the TV on, the "previous channel" function works for a few seconds. But once everything is booted up, then the return button resorts to the TV Plus menu.
Very frustrating. Hopefully Samsung addresses this soon, perhaps with a switch to change the function of the return button. It if cannot be switched, then please make the return button go back to the previous channel function!
ETA: When using LIVE TV AIR, as opposed to Samsung TV Plus, the return button works as always. But once I switch to STVP, the button functionality changes.
- Mute
10-16-2025 09:40 AM in
LED and OLED TVsStill no fix from Samsung on this annoying issue from the last update to Samsung TV Plus menu behavior?
- Mute
2 weeks ago in
LED and OLED TVsPull up the channel guide, not the home page but the channel guide, then push the return button three times in a row without pausing. practice the timing to get it right. it works and seems to be the fastest way to your last channel.
- « Previous
- 1
- 2
- Next »
