- Mute
โ11-13-2025 07:41 AM in
LED and OLED TVsHello everyone,
I recently purchased a S90F (77") TV and I am trying to download update 1131 to get HGIG on the TV. I see that I can't download it via the TV itself, and instead I have to download it via USB. I have tried over and over again, in every combination possible of file location, which files, testing different USB sticks, etc., following the directions and instructions online to a tee. No matter what I do, the TV does not recognize that there is an update on the USB. Is anyone else having this issue? Or perhaps know when 1131 will be available to download normally? It is crazy to me that such an expensive TV is having these issues, and why the update has not been rolled out regularly, especially considering HGIG was removed by Samsung.
Thank you!
- Mute
โ11-13-2025 07:49 AM in
LED and OLED TVsHave you used this guide in particular?
https://www.samsung.com/us/support/answer/ANS10002051/
- Mute
โ11-13-2025 08:05 AM in
LED and OLED TVsIt does recognize that the USB is inserted, I have tried formatting the USB as well and formatting it using the instructions provided (FAT32, no other files, not putting into any folder, etc.). I will try to use another USB to see if that is what is causing the issue. Is there a reason why Samsung didn't just send this update OTA? Seems so odd that they would only send it via USB. Makes me worried something is wrong with the update itself LOL.
- Mute
โ11-13-2025 08:47 AM in
LED and OLED TVs- Mark as New
- Mute
โ01-12-2026 05:31 AM in
He estado intentando actualizar mi QN65S90FAGXPR ( pongo modelo exacto) he probado todas las formas posibles y el TV NO capta el archivo ..
รstoy en Uruguay, y tampoco entiendo porque las versiones de firmware tardan tanto en estar disponibles en Latinoamรฉrica.
Alguien a podido actualizar mediante pendrive?
Este tiene panel QD !! Tambiรฉn lo aclaro x las dudas.
- Mute
โ01-13-2026 01:19 PM in
LED and OLED TVsHello Tonga329,
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/visitcountry/
Did you know? Your region more than likely has a community of it's very own!! Check out the following link and join the community in your region: https://r2.community.samsung.com/
