- Mute
01-18-2026
07:00 PM
(Last edited
01-20-2026
06:16 AM
by
SamsungMatt
) in
My 77" s90f has been going to screensaver constantly during google cast since the tv updated 2 days ago. Worked flawlessly everytime casting everyday since new until after I got an update completed message on screen 2 days ago. Now it goes to screensaver while streaming and I have keep pressing the remote button to get out of screensaver. Please roll back the latest update!!!
Solved! Go to Solution.
- Mute
a month ago in
LED and OLED TVsHello everyone,
we understand how frustrating this may be with the limitations . We ask that if you all who are still dealing with the issue can send us a private message with the model of the television as well as the current version of the software running on your television? We sincerely apologize for the delay in response and any inconvenience this has caused. We want to thank you for your patience.
- Mute
01-19-2026 02:11 AM (Last edited 01-19-2026 02:17 AM ) in
LED and OLED TVs- Restart "casting" devices = Unplug the tv from the outlet for a few minutes, restart casting device as well.
- Ensure screen mirroring features/settings are enabled correctly
After exploring all possible options and still no fix, you could factory reset the TV.
- Mute
01-19-2026
02:00 PM
(Last edited
01-21-2026
12:06 PM
by
SamsungStephani
screensaver cannot be disabled on Samsung oled
Phone restarted. Screen mirroring works fine but you cannot use your phone while mirroring... casting is better as you can still use your phone while casting.
Factory reset on tv does not roll back firmware updates... once applied firmware is permanent until next version is released.
I could buy a chromecast and cast to it as it is hooked to hdmi but man I dropped alot of $ on a tv with google cast!
I will try casting from different devices and different apps tonight to rule out any issue with my s22...
- Mute
01-25-2026
09:31 AM
(Last edited
a month ago
by
SamsungStephani
I see so many people with this problem. ITS ANNOYING. But I don't see any real fixes besides the restart everything suggestions that have been around since computers began.
Screensaver kicks in when casting from any of my 3 Samsung devices.
- Mute
02-01-2026 01:44 AM in
LED and OLED TVsJust to report with frustration same thing on a <1 month old S93F. Worked correctly for the first week or so, and then this.
Does anyone know if this is reported to the correct channel? This is just a forum, is it the right place?
-- some expression of frustration:
It is absolutely shocking that they would allow a critical feature-breaking update like this through without any quality control. Expect a rapid fix otherwise I expect a massive swell of 1* reviews for these broken "flagship" products.
Would love a workaround, currently don't see anything except an external input.
- Mute
02-02-2026 04:19 PM in
LED and OLED TVs- Mark as New
- Mute
01-19-2026 04:50 PM in
LED and OLED TVsI’ve been having this issue too after I recently updated my tv, before the update I had no issues while casting to my TV.
- Mute
01-19-2026 05:10 PM in
LED and OLED TVsI'm having this issue too, and like you it's right after the update. Screensaver comes on when casting. Not just when there's a still image. I'll be watching a movie or casting sports and BAM.. screensaver comes on without fail every few minutes. Tried unplugging and replugging the TV, still the same behavior. Please fix this Samsung. It makes casting impossible to use. Wont recommend this tv to anyone until this is fixed.
- Mute
01-20-2026 06:30 PM in
LED and OLED TVsIl having this issue on s95f OLED. Casting works from the iPhone, but it has this problem (screen saver appears after about 2 min that I cast) with both my android phones casting to the TV.
It was working totally fine since I have the TV! I just started to have this problem recently
- Mute
01-21-2026 02:38 PM in
LED and OLED TVsI Have the same problem with my tv, I'm going to sell it and buy a LG Tv. Samsung Sucks!
