Samsung Account Smart HUB Functionality
(Topic created: 09-21-2025 12:18 PM)
PinkKittee
LED and OLED TVs
I have 3 Samsung Tvs in my home. I'd like to know how to ensure that the same applications are installed across all devices without having to log in to each of them and install separately. I believe that if I've logged into samsung hub using the same account across all devices, I should be able to auto install these apps. It doesn't appear that my Samsung account is truly backing up my applications, if I must install on each tv individually. My friend has Roku tvs in her home and her account does this. Surely Samsung is not the :red_apple: of tvs and far behind in what seems to be basic technology... Help
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
So far I've never heard of or seen a option to automatically download and install apps on multiple TV's. I've always had to manually install them on all of my TV's.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
PinkKittee
LED and OLED TVs
Yes. I think it defeats the point of logging in with an account if we have to do that.
GaryB82
LED and OLED TVs
I've never had a issue with just installing them on my other TV since its a simple process to download and install them.
PinkKittee
LED and OLED TVs
Again, what is the point of logging in with an account if the activities on the account don't follow the account?
Samsung_Moderator
LED and OLED TVs
If you want a guide that shows you how to manage your Samsung TV account. You can visit the link here: https://www.samsung.com/us/support/answer/ANS00046491/
I don't believe there is a feature that allows you to sync your applications from TV to TV.
