Samsung Smart TV how to VPN
(Topic created: 07-24-2024 02:30 PM)
byronwu
LED and OLED TVs
Plug a Google ChromeCast into one of the many USB ports in the back of your Samsung Smart TV.  Install the VPN APP on your ChromeCast.  Optionally, set the VPN to automatically start with a default preference.  You can change this manually, but it is convenient if you have a default. Watch the TV like normal in your country.  Switch to ChromeCast for your VPN country of your choice.
I wrote this b/c other options are complicated e.g. using a router.
I use ExpressVPN and know that can be installed on the ChromeCast and configured the VPN to start automatically.  Check with your retailer, to see if your VPN can be installed on the ChromeCast.
