- Mute
05-19-2025 08:33 PM in
LED and OLED TVsHi, I've been trying to watch TV Plus on my older 2016 TV, and in particular channel 1907 (Bondi Rescue), after I watched it at a friend's house (he has a more modern Samsung TV).
Unfortunately that channel is not on the list of the available ones on my TV.
Firmware is ver. 1260 and it won't upgrade further (most current version).
I wonder how can I update the TV Plus app itself, however it doesn't appear on the app menu.
Should I change zip code maybe?
Solved! Go to Solution.
- Mute
05-20-2025 02:26 PM in
LED and OLED TVsYou can try changing your zip code to see if this will make the channel available, as the channels you are provided are region/zip code-based. Also, please note that this channel can also be missing because of the age of the TV. And some channels may not show because of this
- Mute
05-20-2025 06:39 AM in
LED and OLED TVsHi there, thanks so much for asking about this. Have you checked to see if the channel was removed from your list accidentally? To do this, press Home on your TV remote, navigate to TV Plus, hover over the app, select Channel List, then select Edit Channels. You should see a full list of channels to add or remove from your channel list. Please let us know if this helps.
- Mute
05-20-2025 12:48 PM (Last edited 05-20-2025 02:00 PM ) in
LED and OLED TVsUnfortunately it doesn't show the missing channels.
Also, it looks like only 311 channels are available.
- Mute
