- Mute
09-23-2023
08:14 AM
(Last edited
04-25-2025
07:24 AM
by
SamsungMatt
) in
Hi . I have Samsung UN55F9000AFXZA version TT02,which connect box is compatible with it as I lost the old one with the cables ? Please
Solved! Go to Solution.
- Mute
09:25 AM
(Last edited
09-26-2023
09:26 AM
by
SamsungCaleb
) in
Hello! Thank you for reaching out! The best place that we can recommend is going to samsungparts.com and entering your model there to find the one connect to fit your TV. Or you can also call our parts distributor at 800-627-4368.
- Mute
09-25-2023 09:57 PM in
LED and OLED TVs- Mark as New
- Mute
09:25 AM
(Last edited
09-26-2023
09:26 AM
by
SamsungCaleb
) in
