SmartThings stopped working??
(Topic created: 12-06-2025 06:21 PM)
userBiqYBtg3F3
LED and OLED TVs
Anyone else have this issue? Just realized that it stopped working in my Alexa routines because SmartThings showing the tv as offline. My other 2 Samsung TVs are fine. So I deleted it, and no matter what it wonโ€™t re add. Keeps getting the attached error. No clue what to do now. I ruled out the possibility of if being my network by hooking my phone and the tv to a hotspot. Still nothing. I reset the smart hub multiple times. Signed out of account, signed back in with the smart hub reset. Nothing. Just keeps giving an error. Anyone know how to fix this? I tried it with my iPhone 17 pro max, but also tried with my Samsung galaxy tab as well. So even a Samsung android device wonโ€™t work!
image too big to upload but it says setup via phone failed. Set up manually.
then in top right corner itโ€™s a SmartThings logo and says registration cancelled.
idk how to setup manually, is there a way?
andrewde7eon
LED and OLED TVs
Seems to be a global issue, there's a reddit post about it too.
Submit feedback via the Smartthings App > settings > contact us > Error etc.
Can't register the TV after it went offline.
andrewde7eon
LED and OLED TVs
userBiqYBtg3F3
LED and OLED TVs
Thanks! Samsung support helped. Flash reset fixed it. Problem now is that I canโ€™t get Alexa to turn the tv on anymore, only off.
andrewde7eon
LED and OLED TVs
Sorry, what do you mean by flash reset as I am still having this problem?
userBiqYBtg3F3
LED and OLED TVs
Hold power on tv for 5 seconds. Let go. Then hold power on remote 5 seconds. Let go. Tv will fully factory reset and flash reset which is diff from normal factory reset. All settings are wiped. Worked for me
Cutlass516
Cosmic Ray
LED and OLED TVs
Im having this same issue. I have a Q80 from 2020. I really don't want to do a hard reset just yet. Ut I know I may get to that point. My TV went offline in Smart Things. Diagnostics detected error. I removed the device and tried to re-add it. I get a pop up on the TV that says "registration canceled " hoping the reset works out for me. Just want to add my comment here that I too am having the same issues.
Cutlass516
Cosmic Ray
LED and OLED TVs
Yep...did the hard reset and it worked! My TV was able to connect to Smart Things.
PSet
LED and OLED TVs
I had to change my router from WPA3 Personal Transition to WPA2. After doing this, and a hard reset, I was able to add the device in the SmartThings app and registration no longer cancelled on me. Worked effortlessly. I hope this helps anyone else who is having trouble adding their device back to their SmartThings app. I was getting UBER frustrated.
