TV screen issues
(Topic created: 09-21-2024 06:41 AM)
JROGERS1965
LED and OLED TVs
Started doing this again a couple days ago. it last for about 5 to 10 minutes and sometimes it's a different position/pattern, but basically the same every time I turn on TV.  Should I invest in a new TV or try getting it repaired. Not a cable company issue.
Thanks
MrGhoul
Red Giant
LED and OLED TVs
Did you check for loose cables? I have Comcast cable, and for a little while, I had pixelization from time to time and called Comcast, and they fixed it completely by sending something to the cable box remotely.
MrGhoul
Red Giant
LED and OLED TVs
meself
Honored Contributor
LED and OLED TVs
Unless it's the cables I would get new tv
Diaboyos
Honored Contributor
LED and OLED TVs
A repair usually costs nearly as much as a new TV so most people opt to get a new one rather than repair. How old is it?
