TV stuck on Page 3. Better Solution
(Topic created: 05-06-2025 11:57 AM)
Baltimore_Traveler
LED and OLED TVs
I have an older Samsung TV.  I was doing a reset and it got stuck on page 3 when I did not accept the HUB privacy notices.   I tried to call customer service, they tried a few things and then said I would need to buy a new TV.  This felt as if Samsung had purposely bricked my TV.   I did not give up.  I found the solution on reddit.  I suggest you post this with your customer service folks.  No point having them if they can’t help.
SOLUTION:     HardReset.info:
Second method:
In the beginning, turn the TV off by pressing the Power button on the remote.
SAMSUNG older TV  Power button
Then press the buttons on the remote in this order: Mute, 1, 8, 2 and Power.
Now TV will turn on and the Service Menu should be on the screen.
SAMSUNG QE55Q7FN Service menu
Use the Arrow button to move through the menu and OK button to confirm selections.
I moved to factory reset then did start up again accepting screen 2 privacy notices.
working now.  #samsungcommunity #samsungtv #tv #customerservice
Wyattlynx
LED and OLED TVs
This has worked the best for me however no matter what when I begin the factory reset it continues failing at step 3 I’ve also attempted to complete the setup on my phone however my tv isn’t registering that I finalized the setup on my phone and disconnects after a little bit.
1 Reply
Wyattlynx
LED and OLED TVs
