[Televisions] Stuck on Set Up: Step 3
(Topic created: 11-17-2024 08:40 PM)
dgzr282
LED and OLED TVs
Did a factory reset because the tv menu was not responding.  TV is now stuck on Step 3 and unable to clear/ go back, or reset again.  Prior post says there is a solution but its just a setup video.  Cannot get into menu to do a reset.  Turning tv off and unplugging if for multiple minutes and turning it back on just brings up step 3 again.
HXW444
LED and OLED TVs
Do as before.
When you get to item 2, scroll up to the top and select skip.
This will bypass step 3.
You can then go into the settings and manually select the conditions.
You do seem to lose Samsung account login access to download new apps.
I haven't found this one yet.
But the TV does work again.
meself
Honored Contributor
LED and OLED TVs
I would contact Samsung care
beyagamer
Cosmic Ray
LED and OLED TVs
I agree
beyagamer
Cosmic Ray
LED and OLED TVs
usna1970
LED and OLED TVs
I was having the same problem.  My remote wasn't acting right, so I did a factory reset.  I then got stuck at step 3 of the setup.  I was using smartthings app on my phone to attempt the setup.  I ultimately ended up reconnecting my phone's bluetooth to my tv to get past the step 3 issue.
usna1970
LED and OLED TVs
Hello,
I was able to fix this.  I disconnected the bluetooth connection my phone previously had to to my TV.  When I reconnected my phone bluetooth to my tv, it progressed with the setup.
idontcare101
Cosmic Ray
LED and OLED TVs
That sucks. Tells me the program for this application is garbage and will never work
Sigep49er
LED and OLED TVs
I had the same issue with my 2019 series 7, model UN70NU6900FXZA.
I used the 2nd method on this site to access the secret menu for techs and then reset to factory under options. Hope it works for you.
HardReset.info:
Second method:
In the beginning, turn the TV off by pressing the Power button on the remote.
SAMSUNG QE55Q7FN Power button
Then press the buttons on the remote in this order: Mute, 1, 8, 2 and Power.
Now TV will turn on and the Service Menu should be on the screen.
SAMSUNG QE55Q7FN Service menu
Use the Arrow button to move through the menu and OK button to confirm selections.
High-Ya
LED and OLED TVs
I was getting a message that memory was low and it recommended a factory reset to clear memory - after doing that and during initial setup the screen locked on step 3 = texted with Samsung who said we went thru all steps and it now requires service - we didnt go thru any steps as I couldn't find the controls on the TV so I found you and used the service menu to factory reset again and again its stuck on step three - nothing works forward or back - I did it again and its stuck on 3 again so - not sure what to do now - the mute, 1, 8, 2 and power  seemed to work for others - 3 factory resets and its again stuck on step 3 of setup - any suggestions?
HXW444
LED and OLED TVs
Do as before.
