The Terrace 65 Limited Features
(Topic created: 07-09-2024 07:02 PM)
userTLmIT4rAq0
LED and OLED TVs
Hello,
I have a Samsung Terrace 65 TV and it seems limited on its smart TV functions. The only apps I have are YouTube and Internet and the app store is basically empty. The one app I have the option to download is Amazone Prime but displays an error when I try to download.   It feels like I need a software update on the TV but when I go to to the update option it says there are no new updates. The current software version is 2505 according to the menu. Also I cannot connect to the TV with SmartThings on my phone. My phone sees the TV but it never connects.
Does anyone have any ideas?  Can I force an update with a USB stick?
Ryan
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
Make sure your TV Region is set to USA,
Try the instructions in this thread
https://eu.community.samsung.com/t5/tv/change-region-on-samsung-tv-qe55q80catxxu/td-p/8667704
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
1 Reply
bill-e
LED and OLED TVs
Bill
