There is no way to connect the TV to a wireless network
(Topic created: 04-01-2025 12:36 AM)
Nikita224
LED and OLED TVs
Hello, I have a problem with a Samsung TV:
"Product Information
Model Code: UE46ES7507
Software Version:
T-ECPDEUC-2023.0"
Problem: there is no way to connect the antenna, but it is possible to connect the TV to the network via wireless, that is, to distribute WiFi and for the TV to accept it
But not everything is so easy, I go to connect it to my phone via mobile data, it searches for it for 2 minutes and does not see anything, it just re-transfers to the menu and that's it, I tried to change the assembly, update it, and tried via a flash drive, it does not see, the TV is quite old
Maybe you need to get into the TV itself, change something there or change some settings
For example, at the moment, on my TV, IP, gateway and others are set to 0, maybe I need to change them?
And regarding the phone, distribution, I made different frequencies, and without a password and this way and that, it doesn't see AT ALL
people, help, you're old, it's a pity to throw it away
realaud
Honored Contributor
LED and OLED TVs
The TVs manual should tell you. If you don't have it, it may be available online. You should be able to find the phone specss online as well. I am not familiar with your brand of phone, if you search your settings for casting or screen mirroring you might find it if the phone has it. You can also do a Google search.
Please mark any response that helped you as your solution.
realaud
Honored Contributor
LED and OLED TVs
You have an old TV that is somehow capable of wifi connectivity. You gave no info about your phone. You cannot connect a phone and TV the way you do a computer. You have to use Smart View, and both the TV and phone must be capable of casting. One or both units is not, or you are trying to connect the wrong way. If you have a free HDMI port, you can purchase a streaming device, plug it in and cast through that, but the PHONE must be capable. Which phone do you have?
Nikita224
LED and OLED TVs
Hello, I have the phone. Техно spark10pro
realaud
Honored Contributor
LED and OLED TVs
You have to check the specs of both the TV and phone. They both must be capable of casting or screen mirroring. It is not enough to just be capable of wifi.
Nikita224
LED and OLED TVs
how do I check this. which app is better to use for broadcasting
realaud
Honored Contributor
LED and OLED TVs
