Turn off device detection UN55TO700D
(Topic created: 06-08-2025 04:25 PM)
howcaniusethisstuff
LED and OLED TVs
Hi, when I try to use my tv, it shows me the correct input from the hdmi cable, then it blanks out the screen to walk me through "device detection." It always wants me to "press down if this is a dvd player" or something like that.
I have never once wanted this feature, and it makes the tv painfully slow to turn on. I found some youtube videos claiming I could disable this feature for other Samsung tv's, but nothing about my UN55TO700D. Is there any way to turn off this feature? I have to turn my tv on and off a lot, and this problem turns a serviceable tv into a bad experience.
Samsung_Moderator
LED and OLED TVs
Hello @howcaniusethisstuff! Thank you for reaching out! Unfortunately this is not a feature that can be turned off on your model. You can try to turn off anynet+, but if this doesn't work this will not be possible. Please go to the following. Settings > General > External Device Manager > Anynet+ (HDMI-CEC)
1 Reply
Samsung_Moderator
LED and OLED TVs
