UN55MU6490F cannot control it
(Topic created: 05-17-2024 06:47 AM)
erk2772
LED and OLED TVs
I have a Samsung TV model UN55MU6490F and cannot use the remote to go to setting or to choose TV or internet.  Have reset it to original twice.  It works for awhile then it starts same problem.  When I choose settings it jumps the the Samsung plus or Antenna 3 and I cannot use the source button or on/off button without disconnecting TV from outlet.
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Since you have reset the remote already I would recommend purchasing a new remote from samsungparts.com. While you wait on a new remote you can use your phone to control the TV by using the SmartThings app. You can use the following link to help get that set up: https://www.samsung.com/us/support/answer/ANS00083002/
1 Reply
Samsung_Moderator
LED and OLED TVs
