Update 2123 TV Apps no Atmos output
(Topic created: 2 weeks ago)
Ali3n8
LED and OLED TVs
I have an QNS90D ever since update 2123 tv apps no longer output ATMOS. Is this a known issue or is there a suggested fix?
JerSam1
LED and OLED TVs
I don't use the TV output however to sonos things are fine... Netflix, plex and HBO.
Darkhunter
LED and OLED TVs
QN90D here, same issue, FW 2123 and the Atmos output is broken, we need a fix ASAP
sledtv
LED and OLED TVs
Same problem No Atmos or 5.1 from Netflix, Prime And Apple TV Apps
Switch to Pcm to retrieve audio but still no Atmos
Samsung_Moderator
LED and OLED TVs
Hey Ali3n8! Thanks for visiting the Community. If your TV is connected to a soundbar via eARC and is not displaying Atmos output, there are a few possible causes and fixes to try.
1. Check if Atmos is actually being passed through
On the TV, go to Settings โ†’ Sound โ†’ Sound Output โ†’ HDMI ARC and set Digital Audio Format to Auto or Pass Through.
Ensure eARC is enabled in TV audio settings and Anynet+ (HDMI-CEC) is on.
Play a known Atmos source (e.g., Disney+ or Prime Video with Atmos enabled).
2. Verify the soundbarโ€™s Atmos mode
On the remote, press the Info button (may need to press twice) to check the audio format being sent.
If Atmos is not listed, the soundbar may not be receiving it โ€” try switching the TVโ€™s audio output to TV + Soundbar and ensure HDMI eARC mode is selected
Please let me know if this helps.
Be sure to click " โœ“ Accept as Solution" when you find an answer that works for you.
Ali3n8
LED and OLED TVs
Tried all of the above and still no atmos output. This seems to be isolated to the tv apps, my ps5 which is connected to the tv does output atmos. Only the tv apps do not.
MauroM
LED and OLED TVs
I am also experiencing issues. This works until I turn off my tv. Every time I turn on my TV I need to toggle Anynet+ for the TV to recognize my sound bar. Art mode is also not working...
Samsung_Moderator
LED and OLED TVs
I believe this particular issue may require service. In order to be certain, I would like to gather additional information, and look at this from a case by case basis. Please provide the full model code and serial number of the device as well as your best contact phone number, name, and email
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
