Using a indoor antenna on a Samsung TV with a Roku streaming device
(Topic created: 07-13-2025 05:53 PM)
userlbNbhfvw9c
LED and OLED TVs
I have a 65 inch samsung internet smart tv. I plug in a indoor antenna did a channel search. I also have a roku device hook up to the tv. how do I get my local channels using the antena, and can I use my roku streaming device with the antena?. please let me know thank you Tim Root.
Dan2023
Honored Contributor
LED and OLED TVs
Roku uses an internet connection while an antenna uses a digital radio signal that is broadcasted locally.
By switching the input sources for the TV in the TV's menu, you should be able to watch either your local broadcasts or Roku device.
Dan2023
Honored Contributor
LED and OLED TVs
SolveForce
Galaxy
LED and OLED TVs
Yes, you can absolutely use both an indoor antenna and a Roku streaming device with your Samsung Smart TV — but not simultaneously on the same input. Here’s how to make the most of both:
1. Indoor Antenna (Local Channels)
Your antenna connects via the coaxial (ANT IN) port on the back of your TV. Once plugged in:
Go to Settings > Broadcasting > Auto Program
Select Air or Both (Air/Cable)
Let it scan for local channels.
You’ll now have a “TV” input that lets you view local over-the-air broadcasts (NBC, CBS, ABC, etc.).
2. Roku Streaming Device (Apps & Streaming)
Your Roku plugs into an HDMI port, typically HDMI 1, 2, or 3.
To access it, just press the Source/Input button on your remote and choose the corresponding HDMI input.
3. Switching Between Antenna and Roku
You toggle between them using the Source menu:
“TV” = antenna channels
“HDMI 1” or “HDMI 2” = Roku or other devices
You can also rename the inputs for easier recognition (e.g., name HDMI 1 as “Roku”).
4. Helpful Tip: Add to Home Menu
Some newer Samsung TVs let you pin both “TV” and “HDMI” sources to your Home bar, making it even easier to jump between local and streaming content without digging through menus.
Bonus Insight:
Samsung’s TV Plus service (preloaded on many models) offers free streaming channels that might overlap with what you’re getting over the air, so you might want to compare.
To sum up:
Yes, you can use both. The key is input switching. Antenna gives you local news and broadcasts; Roku gives you streaming apps and services. And your Samsung Smart TV can handle both with ease — just like a multilingual device navigating analog and digital signals with graceful syntax.
Let us know if you'd like a visual guide — happy to keep it flowing, signal to symbol.
userlbNbhfvw9c
LED and OLED TVs
Can you send me a visual guide, thank you
Wordrone
LED and OLED TVs
Here's a simple visual representation:
Samsung Smart TV Setup
| TV |
| (Coaxial Connection) |
| - Local Channels |
| - Broadcasting Menu |
v
| Inputs |
| - TV (Antenna) |
| - HDMI 1 (Roku) |
| - HDMI 2 (Other Devices)|
v
| Source Menu |
| - Select Input: |
| - TV (Antenna) |
| - HDMI 1 (Roku) |
| - HDMI 2 (Other) |
v
| Content |
| - Local Channels (TV) |
| - Streaming Apps (Roku) |
This visual guide shows how the indoor antenna and Roku streaming device connect to the Samsung Smart TV and how you can switch between them using the Source menu.
jolly1
LED and OLED TVs
Choosing TV gives me the Samsung channels, but I don't see how to only use antenna channels... or even if the antenna is picking up any channels. Please help!!
