Vesa holes missing threads
(Topic created: 01-11-2025 05:03 PM)
userglyFT3y1c9
LED and OLED TVs
I have a Samsung tv model # 43RU7100FXZA and 2 of the VESA mounting holes are not threaded and I want to put it on a wall mount. Any solutions to this problem?
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! This is something that will require service. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
1 Reply
Samsung_Moderator
LED and OLED TVs
