- Mute
ā02-14-2025 11:24 AM in
LED and OLED TVsTrying to wall mount 55" OLED TV. Samsung says use M8 size bolts to attach mount to rear of TV. M8 bolts are too small...diameter of holes on back of TV are larger than M8. Am I supposed to use some sort of insert in the hole to adapt an M8 bolt to the hole? And why wouldn't Samsung supply them with the TV?
Solved! Go to Solution.
- Mute
ā02-14-2025 11:48 AM in
LED and OLED TVsOn mine the hole in the plastic is bigger since you can get bushings to go inside the hole to act like spacers if you stick the bolt into the hole you should find threads
If you've found my post to be helpful, Please like my Comments āāā.
If my response resolved your issue, please press the Like and āāā to Accept as Solution button.
- Mute
