un55nu710df red blinking light
(Topic created: 04-14-2025 01:28 PM)
Dark021
LED and OLED TVs
Hello all I am having problems with my tv un55nu710df.
When I try to turn on my tv the Red LED light starts to blink and remains black. I unplugged it and did a hard reset but does the same thing
Please help
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
A blinking red light on a Samsung TV usually indicates a problem with the power supply or a fault within the TV's internal components, often preventing it from turning on. Troubleshooting typically involves checking the power source, performing a power cycle, and ensuring proper connections before potentially needing professional repair.
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
1 Reply
GaryB82
LED and OLED TVs
