Bespoke washer/dryer combo makes loud rattle/grinding noise during drying cycle
(Topic created: 04-04-2025 01:55 PM)
KSWaites
Laundry
Appliance is less than six months old and just started making this loud rattle/grinding sound
Samsung_Moderator
Laundry
That sounds awful!  Sometimes when this noise happens, it's because the washer/dryer is overloaded. If you've made sure it's not overloaded and tried with a smaller load and it still happens, the unit will require service. You can reach out to any of the mods via private message with a link to this thread and your unit's model code and serial number to get service set up. You can also call in to 1-800-SAMSUNG (1-800-726-7864) if you don't feel comfortable providing that info to us here.
GaryB82
Galactic Samsung Care Ambassador
Laundry
I would suggest contacting support they will send out a technician to check it out and repair what's wrong
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
Samsung_Moderator
Laundry
