Blinking Normal Light on Dish Washer
(Topic created: 01-14-2024 10:07 AM)
AbuJennah91
Laundry
Hello,
I have a Dishwasher Model DW80R2031US. The Normal Light continues to blink. The Dishwasher drains the water from inside. Yet, the light continues to blink. If I turn it off. The Dishwasher will automatically power on. It will drain with the chime as well as the Normal Light Blink.
Samsung_Moderator
Laundry
Hello! Welcome to the Community. I am so sorry to hear about the normal light blinking on the dishwasher and would love to assist you with resolving this matter. To get started, I would like to advise the normal blinking light means the dishwasher's leak sensor detects moisture. When this error code occurs, the dishwasher will usually turn itself on and will not allow the power to turn off, as during this time, it will attempt to drain the water away. We recommend for you to inspect the dishwasher itself for any visible leaks. If any leaks are identified please have the dishwasher serviced by a technician as soon as possible using our service link here- https://www.samsung.com/us/support/service/
If you've inspected the dishwasher, and you're certain that there is not a leak I recommend giving these troubleshooting article a review-
1. https://www.samsung.com/us/support/troubleshooting/TSG01001922/
2. https://www.samsung.com/us/support/troubleshooting/TSG01001021/
Please know we are always here and happy to help you directly using any contact method listed below if needed:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option with your full model and serial number.
1 Reply
Samsung_Moderator
Laundry
or
