DV22K6800EW Dryer Stacking Compatible for Washer WW22K6800AW
(Topic created: 11-20-2023 06:06 PM)
dtailer24
Laundry
Hello,
I currently have a ww22k6800aw washer and I’d like to purchase the dryer partner for it. I was wondering if there is a list of compatible dryers, so I could stack the units. The original dryer partner (Model - DV22K6800EW) is difficult to find since the washer is an older model.
Thanks
Samsung_Moderator
Laundry
Hi there, Thanks so much for asking about this. I can definitely understand the need to get a dryer that will stack on top of your existing washer. I have a couple links to help with this. This first link has the two primary dryers that are considered "matches" to your washer.
https://www.samsung.com/us/home-appliances/washers/front-load/ww6800-2-2-cu-ft-front-load-washer-wit...
However, any of the Samsung dryer models that are compatible with the stacking kit "SK-DH" can be stacked on top of your washer. Here's a link to those models:
https://www.samsung.com/us/home-appliances/home-appliances-accessories/washers-dryers/sk-dh-stacking...
1 Reply
Samsung_Moderator
Laundry
