Disable melody on DVE41A3000W Dryer and WA40A3005AW Washer
(Topic created: 05-11-2023 10:08 PM)
Jjimenez54
Laundry
I have both Samsung washer model number WA40A3005AW, and dryer model number DVE41A3000W. Is there any way to disable the end of cycle melody? It would be greatly appreciated!
Samsung_Moderator
Laundry
Hello! Thank you for reaching out! I can see how disabling the chime can be useful.
Depending on your model, you may be able to disable the option. Please check out the following link for a video tutorial -Video Link
If these steps do not work, this would mean your unit does not have this option available.
Please feel free to reach out to our community again if you have any other questions!
freshdog
Laundry
Camera upgrade
Diaboyos
Honored Contributor
Laundry
I don't know about those but on my LG it's impossible unless you tear the speaker out which I'm about ready to do.
Samsung_Moderator
Laundry
