Dryer - motor noise
(Topic created: 02-09-2026 08:44 AM)
Anya003
Laundry
I received today new washer and separate dryer, it was installed by technicians and I ran my first laundry.
    fter 1 min there is that loud motor noise. Can anyone tell me if that is normal? I can hear it through closed doors. It drives me crazy. Sometimes it dissappear.
SamsungRon
Laundry
Welcome to the Community! We understand your concern that your brand new dryer is making noise right after it was installed. We certainly wish to help with that.
Please reply with your model number for the dryer for further assistance specific to the dryer model you have.
If this is not a US dryer, we kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/visitcountry/
Did you know? Your region more than likely has a community of it's very own!! Check out the following link and join
the community in your region: https://r2.community.samsung.com/
1 Reply
SamsungRon
Laundry
