Front load washer WF45R6100AP/US - part to replace washer cycle text that is no longer readable
(Topic created: 03-28-2023 07:43 AM)
rustyrepublic
Laundry
I'm having a really hard time trying to identify a part that will replace the text on the front of the machine that describes the wash cycles, Normal, Heavy Duty, Whites, Bedding, etc
I understand ordering the Full Control Panel Assembly DC97-21942B will achieve that but that is very expensive to replace some text.
Is there another part / sub-component of the control panel assembly that has the text and can be ordered separately without replacing the entire control panel? I can't tell if Cover Panel DC63-02337B is the part I need
Thanks
Samsung_Moderator
Laundry
Hi there, Thanks so much for reaching out about this. I can certainly understand the need to be able to read your control panel. There may be a panel overlay available for your model. I recommend reaching out to our parts department directly to get the most accurate information about available parts. You can reach them by calling 1-800-627-4368.
1 Reply
Samsung_Moderator
Laundry
