- Mute
12-23-2025 06:41 PM in
LaundryI have a wa52j8700ap/a2. Started not dispensing “very hot” water or “hot” water properly. Some cycles will dispense a little hot water, but it’s not hot like it used to be. I ran diagnostics to check if it was a solenoid issue and got the TC1 error code upon doing so. This pointed to a faulty thermistor. I changed the thermistor and verified proper connection twice, but the code still comes up in diagnostics and only dispenses a little hot water. I checked water lines and verified no particles or blockage in the hot water hose. Curious what else could be the issue other than a bad control board. Any ideas?
- Mute
12-23-2025 06:47 PM (Last edited 12-23-2025 06:47 PM ) in
LaundryI'd suggest contacting a repair center for help with this.
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
