Top load washer drum clicks when it spins clockwise
(Topic created: 05-12-2025 08:09 PM)
Inland_emperor
Laundry
I have a WA45T3200AW/A4 top loader washer. Anytime the drum spins or moves clockwise it makes a clicking sound. Counter-clockwise, it spins and moves quietly. What could cause this?
Samsung_Moderator
Laundry
Hello Inland_emperor,
Thank you for reaching out to our Samsung Community. From knowledge, A noisy washer or clicking sound during the spin cycle can be caused by several issues, including an unbalanced load, but not excluding things such as worn parts like the drum bearings or drive belt, or a problem with the motor or transmission.
We recommend having a service technician diagnose the problem for an accurate resolution to determine the cause and proper repair, if needed. You can contact a service provider by using this link- https://www.samsung.com/us/support/service/. You also can send a Private Message by selecting any moderator and clicking on the chat option with your full model and serial number, and we would love to assist you further there.
1 Reply
Samsung_Moderator
Laundry
