Washer Eco Drum Function and Cleaning
(Topic created: 05-09-2022 04:46 AM)
userGgzLFcSTcj
Laundry
Hello,
If I use the Eco Drum function on my Samsung washer, do I sometimes have to use a global cleaning solution (descaling, killing bacterias...).
Why I am asking that because I've seen on the manual "Do not use any cleaning agents for cleaning the drum. Chemical residue in the drum deteriorates the washing performance".
Thank you!
Samsung_Moderator
Laundry
Great question! No matter the settings used during wash cycles, the washer will require regular maintenance to ensure the best performance. The link below has everything you need to know about keeping your washer clean and fresh.
https://www.samsung.com/us/support/answer/ANS00030150/
Samsung_Moderator
Laundry
userGgzLFcSTcj
Laundry
Perfect, thank you!
