- Mute
โ12-27-2025 05:24 AM in
LaundryHello,
I have been trying to debug an issue with my washing machine. The other day the washer stopped finishing a regular wash cycle. The cycle would run for 10-15 minutes and then at some point the timer wonโt decrease nor will the washer do anything - it will just sit there. You just hit the pause button then play button, but nothing will happen.
I tried unplugging the washer for 10 minutes. Then tried running a self clean cycle - same result, itโll run for about 10-15 minutes then sit there and do nothing without timer decreasing. I ran a calibration which supposedly should take 1-3 minutes, but it took closer to 20 minutes to complete. Then I ran the self clean cycle againโฆfinally it completed the cycle! Excited, I then put my clothes in to run a regular cycle and now the washer wonโt even attempt to do the cycle. It locks the door and makes some familiar noises and the clock then has the numbers running in a circle like it is thinking and then makes another familiar noise and unlocks the door like itโs waiting for me to choose a wash option. 3-4 iterations of this, I finally get a 3C error code.
โ
โ
โ
- Mute
โ12-27-2025 05:43 AM in
LaundryI had this issue once with a washer - even went out and bought a new washer, only to find the same issue. Turned out it was the outlet it was plugged into. It was able to supply just enough power for part of a wash cycle, but would quit when any real power was necessary, like the start of agitation. Interestingly enough, it did not trip the breaker, just stopped. I would never have suspected the outlet, as anything plugged into it worked. So, my suggestion is check the outlet or plug the washer into another outlet to see if it completes a wash cycle. It it turns out not to be the outlet, then put in a service request, there may be an internal misfiring.
- Mute
โ12-27-2025 10:50 AM in
LaundryIf you've found my post to be helpful, Please like my Comments โโโ.
If my response resolved your issue, please press the Like and โโโ to Accept as Solution button.
- Mute
โ12-27-2025 09:57 PM in
Laundry
