Washer tub fills with water after each wash
(Topic created: 02-21-2026 04:46 PM)
Adelqui
Laundry
After each wash it appears all water has drained and spin. However after 24 hours the tub fills with water
Samsung_Moderator
Laundry
Hello, Adelqui, Welcome to the Community! We certainly understand your concern with the washer filling with water after the cycle's over, and we want to help.
We have a couple things to help pinpoint the issue:
  • Does this happen after every load is run and the clothes removed?
  • Please check that the washer is level and the drain hose is not placed more than 6 to 8 inches into the drain pipe.
To provide better information for  your specific washer, please provide your model number.
On a front load washer, you can find the model number around the opening of the drum.
On a Top load washer, you can find the model number under the lid.
If the water is constantly filling without the washer turned on, please also turn off the water supply valves, and reach out to us for service with one of the following options:
Online at https://www.samsung.com/us/support/service/
Contacting Customer Support at 1-800-Samsung (1-800-726-7864)
Contacting a Moderator through Private Message
For the private message option, please provide:
Model Number
Serial Number
First and Last Name
Best Contact phone number
Address where the unit is located
Email address
BlueSkies
Comet
Laundry
What cycle is it on?
BlueSkies
Comet
Laundry
Yikes I commented on the other post
BlueSkies
Comet
Laundry
😮 what cycle is it on?
meself
Honored Contributor
Laundry
Not sure
Samsung_Moderator
Laundry
Model Number
Serial Number
First and Last Name
Email address
