Washer won’t power on
(Topic created: 04-08-2023 03:17 PM)
MrPf
Laundry
Samsung
model number
WA45M7050AW/A4
My washer won’t power on. A technician who looked at it said it was the control board. I purchased a Samsung control board, noise, filter, and also a new power cable. I also had another electrician come out and replace the wall socket. The washer still will not power on. I also tried running a power cable to the washer from another outlet and it still won’t power on.
I also had a electrician come out and replace the wall socket. The washer still will not power on. I also tried running a power cable to the washer from another outlet and it still won’t power on.
Help
Diaboyos
Honored Contributor
Laundry
You need to contact Samsung directly. This is a user forum.
Samsung support 1-800-726-7864
Samsung text support text START to the same number.
1 Reply
Diaboyos
Honored Contributor
Laundry
