After battery replace notification ,phone hanging issue faced,system UI not responding
(Topic created: 02-21-2026 01:44 PM)
Premnath
Legacy S Phones
1month ago I received auto notification in mobile  about battery replacement, after 1week mobile hanging using of any apps or normal settings now frequency of issue increased 5mins once,
Error like System UI not responding, wait or close app like messages, some time mobile automatically going off and switch ON.
I free the storage also ,now 32gb free in filemanager
This issue related battery failure or other components or software issue.
Mobile Samsung s20fe 5g
4.5 years old mobile
nullandvoid
Comet
Legacy S Phones
You were notified your battery was failing and you ignored it. It would not be unusual for a battery to fail after 4.5 years. Back up all your stuff before your battery fails completely. I'd say it's better to go for a new phone than replace the battery, as you would be at the end of your update cycle.
The phone told you the issue was your battery. Why would you think it's a software or other component issue?
meself
Honored Contributor
Legacy S Phones
Battery issue you should of addressed as for free space or available storage that will affect your performance also
Robin621k
Honored Contributor
Legacy S Phones
As @nullandvoid has warned you, it's best to back up your device anyway you can. If you have a complete system failure you might lose the almost 5 years of stff on your phone.
SatoshiNakamoto214
Legacy S Phones
โค
